Enables the generation and processing of BOOTP packets on a VLAN to obtain an IP address for the VLAN from a BOOTP server.
| bootp | Enable BOOTP client. |
| ipv4 | IPv4 client. |
| dhcp | Enable DHCP client. |
| ipv6 | IPv6 client. |
| vlan | Specifies a VLAN name. |
| all | Specifies all VLANs. |
Disabled.
If IPv4/IPv6 keyword is not specified , ipv4 would be taken as default for the mentioned VLAN.
The following example enables the generation and processing of BOOTP packets on a VLAN named "accounting":
enable bootp vlan accounting
The ipv4 and ipv6 keywords were added in ExtremeXOS 15.6.
